Results 1 to 13 of 17
    Jun 2002
    I'm in the process of having to clean up after some sloppy installation work by my builder's HVAC subcontractor.
    Basically, they left gaps between the supply and return boots and the surrounding construction, which is allowing some crawlspace/attic air to leak into the returns and supply air to leak into the crawlspace/attic.
    Downstairs, all the supplies are in the floor, so I had some gaps open to the crawlspace. I sealed between the boot and the wood or tile with metal tape which would stick to both surfaces pretty well and seemed to work OK.
    Upstairs, though, all the openings are in the ceiling drywall, which means I'm sucking some air into the returns from the attic and/or blowing some supply air up there also.
    Tape isn't going to stick to the drywall too well. What should I use here? I was hoping there would be some sort of expandable-foam insulation type product that woudn't be too hard, but I'll use whatever you guys recommend.
    I just used Alex-plus siliconized latex caulk. About $2 a tube. Soap and water clean-up. Did it from inside the house by removing the registers. I hate that spray foam.
    Bob's right that is the best way.Let it dry before reinstalling the grilles,so they'll come down when it's time to paint.
    Jun 2002
    OK, thanks! I just didn't want to have to bet in there with a putty knife and mastic or something like that.
    Jul 2005
    Joe, we do this all the time. If the gaps are small, caulk will work. HOWEVER, be aware that silicone of any kind will contaminate the surface and subsequent paint will fail.
    If the gaps are too large for caulk, and if you have access to the back side of the drywall, you can use expanding foam. The latex foam is much easier to use than the urethane and cleans up nicely. It is not as good, however. No free lunch.
    Jun 2002
    Well, it turned out that once I started removing some grills that I had gaps that are too large for calk (like 1/4" or maybe even more).
    So, I went over to the local HVAC supply house and got a tub of duct mastic. Can I fill gaps this big with the mastic or is this asking for trouble?
    (I could go the foam route, but the stuff I saw required acetone clean-up while the mastic is water-based.)
    1/4-inch backer rod and caulk?
    Rapid City, SD
    Mastic (aka Pookey) will fill that size gap pretty easy. If you need a lil something to help it fill the hole, use some of the tape the drywall guys use or something similar.
    Slap it on thick though and it'll fill some pretty good size gaps.
    in a house, Appomattox, Va.
    You can goop the mastic on the backside of boot?
    May want to watch for the drywallers forcing the boot out of position. If you have metal plaster frames they'll slam up the sheetrock and push the boot 1/2" up and create gap between the boot and back of drywall. Them you have to cut the drywall to get everything back into place so it can ve sealed.
    Did they seal the duct? air handler?(not the doors) you'll loose lots of air if they didn't.
    Col 3:23
    Nov 2000
    Eastern PA
    I know its messy, but that expanding foam is the way to go. Shoot it into the gap and let it do its thing. Leave the job for the day and go back later to trim the excess foam and you are done with it.
    That foam is also great for leveling condenser/heat pump pads. Just level the pad with rocks, pieces of wood or whatever is availble and shoot that foam between the ground and the pad all the way around. Let it set for the night and trim the foam with a knife to conform to the side of the pad.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Jun 2002
    So, are you on board with the latex/water based foam or should I use the oil-based stuff?
    Nov 2000
    Eastern PA
    I have not heard of water based latex foam. Sounds like the better way to go. That oil based stuff is a real pain to clean off of anything it gets onto before it has cured.
    Jul 2001
    RoBoTeq, DAPtex is the brand of latex foam I use. Comes in a blue can. A lot better than GreatStuff, in the red can. It is really good stuff. I buy it at Lowes but I'm sure other places also sell it. I like the fact that this stuff won't overexpand like the polyurethane foams. It only expands until it meets resistance. It won't buckle or warp objects it comes in contact with. One can can seal around all of the boots in a new home.
