Thread: Thermostat for geothermal
07-25-2005, 10:11 AM #1
- May 2005
- 148
First easy question: A geothermal system takes a thermostat for a heat pump correct?
Second question: What brands are decent and what brands should I not even consider?
Third: Given that all I really want are some basic controls like temp, humidity, reducing energy consumption while I'm at work, and minimum down time.......any recommendations for a particular model?
07-25-2005, 01:41 PM #2
- Apr 2005
- NE PA
- 697
Heat pump thermostat is correct. Some Geo units require a 3 stage heat, rather than the normal 2 stage.
I like the higher end Honeywell programmable with touch screen control.
paul
07-25-2005, 01:47 PM #3
- Apr 2005
- NE PA
- 697
paul
07-25-2005, 02:26 PM #4
- Sep 2002
- 3,676
Not really..depends on if you'll be adding supplement heat or not.
If not all you need is a stat that will energize the reversing valve coil.
