Results 1 to 7 of 7
Thread: Sunday night at 11
07-25-2005, 12:06 AM #1
Professional Member*
- Nov 2001
- east kansas
- 7,980
This sucks because my first call is at a house with a ground source pool heater tomarrow. I've serviced this home a couple of times. They have money and are the type.
Last service I added a bunch of water to the ground loop. Brought the pressure up to around 75 psi. I didn't know it had a 12 pound expansion tank. The guy was pissed. Thought I screwed up his loop. Called the boss and boss agreed that the loop should never need water added. This is different that what I learned over the years at another company and factory training from WaterFurnace.
Okay done crying.
07-25-2005, 12:18 AM #2
lynn
Is this like a chilled water system? Closed loop?
07-25-2005, 07:21 AM #3
- Nov 2001
- east kansas
- 7,980
I think this is a HydroTherm pool heater (Ground source heat pump. I believe it has three loops. Close loop that heats and cools water. (Exchanges heat with the refrigeration loop). This water flows to a heat exchanger that the actual pool water flow through. (That would be the only open loop.) The of course the ground loop.
07-25-2005, 07:41 PM #4
Last post
Explain that to your wife. Then let us know what you said. I know what you said was in english, but what did you say?
07-25-2005, 09:29 PM #5
- Nov 2001
- east kansas
- 7,980
It's a HydroHeat brand.
Loop one is the ground loop that all ground source heatpumps have.
Second loop is a water loop to the heat exchanger. On a regular ground source HP it would be the air side.
Last loop is the pool water to the heat exchanger.
07-25-2005, 09:32 PM #6
- Nov 2001
- east kansas
- 7,980
Re: Last post
My wife just smiles and nodds.Originally posted by oroy54
07-26-2005, 12:24 AM #7
Think of it as a boiler, without the fossil fuel burner, and you'll be fine.
It really is that, a boiler. "Indirect fired", technically.
