Results 1 to 8 of 8
    Jul 2005
    Is Freeze 12 compatible with r22?
    South/West of Quebec in the other part of Canada
    does your freeze 12 have an "R" infront of it? If it does you might be able to use it..providing you double it and take away 4 then add 2.
    [Edited by key on 07-24-2005 at 08:57 AM]
    Jul 2005
    It's Johnsons Freeze 12. All it says is: "Replaces R-12" It says nothing about R-22
    That was a little humor.No they are not compatable.
    Jul 2005
    Thanks for the reply. So there is no replacement for R22?
    Apr 2004
    Palmdale, CA
    Replacement for R-22? R-22 is readily available at a supply house if you are EPA certified. Don't understand what kind of replacement you mean.
    leland nc
    there are replacmants for r-22 but there is not reason to use them 22 is easly available and works. any refrigerant you need to be epa cert. the fact freeze 12 and 134a you dont need cert for burns a hole in my but
    Jul 2005
    you DO need a certificate for Freeze 12 but not for 134A. But the EPA has really screwed things up. They are now regulating refrigerants that do not harm the ozone layer, which was the ONLY reason for regulation in the first place. Because they put so much effort into control rather than alternatives, we are stuck with a corrupt, non-sense, system. Those with certifications can only blame the EPA.
