    Jul 2005
    I am looking for a part number or any type of reference number to replace a condensor motor in this unit.
    Yes, I know its old (33 years I would guess).
    Yes, I know I SHOULD replace the whole unit (hard to justify on a cabin that gets little use)
    Generally spec would be fine also. I think its a 1/3hp motor.
    I dont know the part number.Go to fasco.com(or parts supply retailer) and a close match can be found.
    HSW4 I assume is the only visible model number? Is the specs visible on the motor? also if the model number is gone sonetimes the charging chart on the inside of the unit will show the model number if it is still intact. I'll check my parts program and get back to you if I find something.
