    Jul 2005
    The condensate line to my air handler is not graded properly, it's too long (30 ft) and I guess the low head pressure causes water to back up in the drain pan. Being an estimated 25+ years old the bottom of the air handler which must contain a GI drain pan is rusted. So there's a steady drip from the bottom of the rusted handler and if I don't purge some of the water from the line during hot days, it leaks faster from the air handler. My question is whether it could get to a point where the return air can pick up this condensate. I know that air must exchange heat with the evaporator coils, but I don't know what separates the air from water in the drain pan. Thanks in advance and thanks for this great site that has provided a lot of valuable info for me..
    Fix the drain and install a condensate pump. save your money for new system.
    Jacksonville, FL.
    Ditto.
    Apr 2004
    Gravity
Plumbing Talks | Contractor Magazine
Forums | Electrical Construction & Maintenance (EC&M) Magazine
