Results 1 to 13 of 30
    Apr 2011
    Erlensee/ Hessen Germany
    York Chiller Password
    i need the password for york chiller: (service)passcode
    Ontario Canada
    C-A-L-L- A- P-R-O-.........
    Oct 2001
    spell Y O R K on your phone keys ....................# # # #
    "when in doubt...jump it out" http://www.youtube.com/watch?v=U1qEZHhJubY
    SouthEastern Virginia
    sorry but New Guests do not have these privileges.
    It might get loud!
    atlanta ga.
    there is two, 9675 and 1380
    Apr 2011
    1380 and 9675 do not work. Is there a different password?
    atlanta ga.
    what type of york chiller is it and what panel
    Apr 2011
    YCWJ and Millennium Recip Chiller Panel.
    How do I get to the programming level? Maybe I'm doing something wrong?
    atlanta ga.
    Apr 2011
    Thank you very much.
    Apr 2011
    Can be adjusted so that the head pressure? The machine was switched to a different refrigerant.
    atlanta ga.
    you can program the discharge pressure cutout and the discharge unload setpoint. you will still have the mechanical high pressure switch in the circuit. you can set the cutout for r-22 from 200-399psig and r134 128-275 psig the unload you should set 20-25 psi below the cutout setpoint. good luck my friend.
    Apr 2011
    Do you have a manual about it. Perhaps for the panel?
    The change is from R22 to R422D. This refrigerant is not known to you. R22 is banned in Germany / Europe.
