Results 1 to 8 of 8
    Hello, I had a Bryant 4 ton 12 seer condenser installed about 3 years ago. The unit sits on a concrete pad with rubber isolation pads in between. Recently, the condenser, makes a banging noise when it starts up. The unit cools perfectly. I have checked the compressor mounts, bolts holdng the fan and cage and all seems ok. Any suggestions before I call a tech?
    Thank you
    Shut the unit down and call a tech quickly.
    When you give a lesson in meanness to a critter or a person, don't be surprised if they learn their lesson.
    Houston,Tx.
    If it ain't broke no tech can fix it would be my guess, as old Dad use to say If you just got to mess with it if it ain't broke make sure you break it were it can't be fixed.
    Henderson, NV
    Probably a scroll compressor in it , correct
    Yes, it has a scroll compressor. Is this normal for scroll compressors when they start?
    leland nc
    you can get a thump when a scrol turns on
    check to see is the refrigerant lines are touching the wall where they enter the house if they are the noisw will be ampilfied
    Put a sound blanket over the compressor.
    Feb 2005
    Dothan, Al
    Have yu replaced yur filter?
    Is the indoor coil dirty??
