Results 1 to 12 of 12
    Jul 2005
    I have a 2 ton air condition unit for my unstairs. the system during the hottest part of the day is not cooling. I have check pressures and they are right in range per what I learned in class. I did have to add some last year and was thinking there may be a little moisture in the system. Does anyone have any ideas before I remove the refrigerate and replace the filter and recharge?
    Metro ATL
    If possible, can you post the measurements you took? Also check the delta T across the evap coil, superheat, subcooling, and amperage on the compressor and it's FLA. Also, if you could post the model number of te unit you have, it will go a long way to helping us diagnose your problem.
    Check attic heat gain in the ducts. Compare temp coming out of registers with temp leaving coil. Also compare temp entering return grilles with what gets to the coil. If pressures look good, you don't have refrigeration problem. Airflow, duct heat gain, or sizing issue instead.
    Jul 2005
    The head pressure was around 270 and the suction was around 78 to 80 the amp draw was 8.9amp and the delta t I dont remember.
    Without outdoor ambient that doesn't tell us anything.
    Same with suction, need to know indoor bd, and wb.
    But at 270 head, it better be real hot outside.
    Have you serviced it lately, like clean the condenser, and evap coils.
    Jul 2005
    The out door temp was 94 yesterday when all this started. and I did not get the indoor db.
    In order to get a good answer that info is needed.
    indoor wb, and db
    outdoor db
    suction line pressure and temp
    liquid line pressure and temp
    metering device
    coil delta
    brand, model.
    Jul 2005
    Wink
    Without knowing the indoor temp. I really can't say if the pressures are right, but judging from your pressures and your description of the problem, you may need to clean your outdoor coil. If that doesn't correct the problem, the system may be overcharged and you may need to adjust the refrigerant charge. Make sure that your filter is clean before adjusting refrigerant.
    Jul 2005
    Ok it the weekend and here we go.
    Indoor wet bulb is 67
    the delta T is around 9 to 10
    The head pressure is changing between 300 and 325 psi
    and the suction is changeing between 70 and 80 psi
    the line temp on the suction is 87.4 3 inches from service value.
    and the condensor air is 95.7 going in and 119.7 leaving.
    So If any one can give me an idea before I pull the refrigerate and start over that would be great.
    Joseph
    When you had to add some last year, was it running in a vacuum.
    Those readings indicate some non condensibles.
    I'd also clean the coils while I was at it.
    So recover, new filter, deep vac and recharge is inline.
    You should fix the leak.
    Your superheat should be about 13 for the conditions you posted.
    Jul 2005
    got it
    You are correct. I did just that and the super heat is 13 now and every is running smoothly. The head pressure and suction pressure is a little high right now but the temperture up stairs is also around 80 degrees. The suction pressure is around 80 and the head pressure is around 320 psi. The suction line temp temp is right on the money at 68.7 it is with end the +- range.
    So thanks for your help.
    Louisiana
    Check to make sure that your inside coil is clean, also, turn the power off that powers your inside unit , remove the panel that covers your blower motor, see if the motor and the squirrel cage isn't dirty, if it's really dirty than you'll have to remove it and clean the cage with a hose and vacume the motor the motor but don't you air pressure on the motor, before cleaning the cage though remove it from the motor.
    If all is well with this than it might be time to call in a tech to inspect the system.
