Results 1 to 13 of 16
    Jul 2005
    The contractor that installed my 2.5 ton split system used the incorrect evap. fan blower. On low speed it is pushing out approx. 1400 cfm. According to the maufacture, this unit should be at 1050 cfm. My question is can I either replace the fan speed circuit controller with another one or can I put an inductor in series with the motor to limit the current to slow it down or do you recommend replacing the the whole blower?
    Cincinnati
    Why don't you get your contractor to fix it if he installed improper equipment?
    Jul 2001
    Gold Coast of Connecticut
    your duct work is oversized that much.........hmmmm!
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Jul 2005
    Blower
    The contractor that installed my equipment is out of business.
    find who the local manufacture rep. is and ask them to recremend some one. usualy the manufacture will stand behind the equipment instaled some what. thay are not responsipal for the work done. they can point you in the right direction. this should be repaired by a service company not the home owner.
    Henderson, NV
    Elaborate a bit, what make is the system, and is it a variable speed blower motor
    Apr 2004
    Whats the actual airflow? Stamped ratings dont cut it.
    Jul 2005
    Manufacture
    The name of the manufacture is Luxaire. There is a manual blower speed control on the blower. I already have it set on low speed.
    [Edited by rnoecker on 07-22-2005 at 11:43 PM]
    Jul 2005
    Air flow Measurement
    The actual airflow that I measured coming out all the supply ducts totaled 1400 cfm.
    [Edited by rnoecker on 07-22-2005 at 11:41 PM]
    Houston,Tx.
    Install an air bear filtering system that will slow down the old motor plenty probably put you right in the old ball park of the needed cfm's.
    By the way how did you measure the cfm's? I use a tape measure and measure from the grille to end of air flow but it's a special tape measure, I stole it out of Doc's tool bag.
    Model number of blower and coil is????
    Apr 2004
    Check the pressure drop accross the coil. We'll see how accurate 1400 is.
    Central Kentucky
    Re: Air flow Measurement
    Just curious what did you use to determine the airflow with?
    Have you set up a Google alert for Carbon Monoxide yet?
    Click here to find out how.
