Results 1 to 10 of 10
    Jul 2009
    Columbia, MD
    PM on a job we've done 2 systems in 3 years
    Click image for larger version.
    Pittsburgh
    nice ..... isent there apposed to be pick up traps when you run it that high? or is it shorter then the pic makes it
    Who the hell put this return in the bathroom.
    Jul 2009
    Columbia, MD
    ive always wondered about the traps. i thought u needed traps if the OD unit was above the ID coil. If someone could please guide me in the right direction it would be greatly appreciated. We've done more installs like this and the equipment has lasted 20 years with no compressor problems. so i guess its ok? that is about 25-30' vertical run. my 32' ladder extended to the top of the roof
    Pittsburgh
    nvr mind doing some reading onlie and ran across this
    Because R-410A and POE oilmix so well together, oil-trap
    installation is generally not required on R-410A systems.
    http://www.rses.org/assets/r410a/0308_Feature2.pdf
    is that the infinity series? we do the evolution i love this system except the pain in the butt controll
    Jul 2009
    Columbia, MD
    its a performance 15seer which is compatible with infinity with a fv4cnf003 a/h
    Jul 2009
    Columbia, MD
    good find on that article. if only everyone used nitro while brazing and actually flushed out old linesets when retrofitting
    Aug 2009
    Michigan
    Carrier recomends a trap in the suction line if its 20 ft or higher.
    If anything, run the lines up a bit out of the attic air handler so that during the off cycle, liquid from the coil doesn't flow downhill to the compressor. Trap in the suction line is for condenser above evap.
    I lived in a 3rd floor apartment briefly in the early 80s. When my A/C ( ground) came on, it sounded like a machine gun going off for a few seconds as the old Copeland cleared out the liquid!
    Washington
    A liquid line solenoid is in order.
    Jul 2009
    Columbia, MD
    yes. the tubing is higher then the evap coil then goes down vertical and bends into it
