Results 27 to 29 of 29
Thread: FX10
05-02-2011, 06:35 PM #27
- Feb 2005
- Edmonton, AB Canada
- 519
Good day BACNet,
Indeed, I suspect that there will not be a company or companies making a complete product line that is strictly N2 based. However, N2 and MS/TP share the same electrical interface (RS485) and so it is rather trivial to have the same hardware that has different firmware versions to support MS/TP, N2, etc... As an example, virtually all of our newer hardware has RS485, Ethernet, gobs of power/RAM/Flash, and is field re-programmable (so the user can change from one protocol to another in the field)... consequently we can support N2, BACNet MS/TP, BACNet I/P, TCP/IP, Modbus, etc... If we can do it, and we are a small company, a number of other companies that are significantly larger than us can as well. Whether or not they want to is another issue altogether...
Cheers,
Sam
05-02-2011, 06:45 PM #28
- Feb 2005
- 519
Good day Prostock,
Like I said in an earlier post, I know of a couple of reasonably sized FX-07 projects (connected to FX-60, etc) that are somewhat on hold for the various people to decide what to do given the FX-07, etc notice of discontinuance. I know in one case there was an issue in being able to find 30 or 40 FX-07s for one portion of the project... some were eventually found, but what will supply be like in 4-6 months from now? Hard to say, as it is anyone's guess. All I know is that I am glad that I am not the one making the decision... Sorry, I cannot be more help!
Cheers,
Sam
05-02-2011, 06:59 PM #29
- Jan 2008
- 49
This job is FX10 OEM style boards factory programmed supplied in water water source heat pumps. It is the FX10 that is in question. All I would do is map them up and do some S/S and setpoint control. Currently N2 is winning the conversation.
I would not think of using the other FX controllers due for discontinuation to layout this job. I am inquiring of the life of the FX10 to the JCI rep and will see from there.
Thanks.
