Results 1 to 11 of 11
    NJ
    Hello everyone and thank you in advance.
    Here goes.
    Do you need to install a chimney liner IF you are replacing an old unit with an 80%+ induced draft unit?
    Jul 2002
    Zelienople, Pa
    yes
    Unless its a clay liner, or other approved liner in the chimney already. And the chimney isn't too big for the new smaller 80% furnace.
    NJ
    Thank you (beenthere) yes it does have clay liner, It did not make sense to run another liner down there.
    Thank you
    Dec 2003
    you need a liner
    NJ
    I thought ( INDUCED DRAFT) took care of the slow moving gases( only mid-efficiency) going up before they condensate? or no?
    If 1 or more sides is exposed, line it.
    If furnace is alone and no WH, line it.
    Inside chimney with water heater, gas code sez: the flow area of the chimney cannot be more than 7 times the outlet area of the smallest draft hood appliance.
    Well, that would be your water heaters with likely a 3" (7 sq inch) outlet. So if the internal dimensions of your tile liner are more than 49 sq inches, code says line it.
    Of course if you don't want to take any chances, line it. Liners are cheap, chimney repairs aren't!
    flue gasses are lower temps. with an 80 furnace as opposed to an older 65-70.
    therefore condensation will occur at colder temps.
    the flue gasses are acidic and will eat through any mortar joints in the clay liner.
    new chimney= $$$$$
    LINER=$$$
    it's up to you i guess.
    Dec 2003
    Hmmm, my chimney has long since been orphaned to just WH duty but is on an inside wall, so I guess that's why it still drafts properly.
    NJ
    THANK YOU ALL
    Direct vent it is then. lol
    There is no motar joint on clay liners.
    Teracotta, yes there is.
