Results 14 to 26 of 26
    Jan 2002
    Ft.Worth,Tx
    No , transition, wood in pan= rot did not see the filter, but TAPE on doors is must in TEXAS heat....But , don't agree with no secondary drain line.
    'Life begins with the journey each day'
    Mar 2011
    Double liquid line drier.
    Always see that on Trane / Am St.
    One guy told me that was a strainer inside the C/U so an external was needed.
    Riiiiiiight.
    Perhaps not wall of pride but have seen MUCH worse...
    Jul 2009
    Fort Worth, Texas
    Quote Originally Posted by SoFlaDave View Post
    Every time I see silver tape all over an air handler I just sit in the attic and weep over my sliced up finger tips hahaha
    This is what id like to do to the guys that do that kinda crap!
    Mar 2011
    Las Vegas
    Where I come from, this doesn't count as a Wall of Pride photo. What's with the wood support under the air handler?
    Feb 2007
    Corpus Christi, TX
    There is rubber pad on top and bottom of the pressure treated wood.
    Primary Drain is ran then secondary has a float switch, the pan has got an auxilary on it, and a float switch as well...
    More than enough protection there.
    Nov 2007
    Sherman, TX
    Hang in there, TC....Christ himself could post pictures of a job here, and it would get ripped....
    Technical incompetence is NOT a sales tool....
    Phoenix,AZ
    Quote Originally Posted by John Markl View Post
    I know. I feel bad for ripping on it myself. I'm really surprised nobody ripped my own install. I ain't even got a drain pan underneath it.
    http://hvac-talk.com/vbb/showthread.php?t=696411
    Jan 2002
    Ft.Worth,Tx
    Quote Originally Posted by Bill208 View Post
    Heres the way to hang them guys. www.Quick-Sling.com
    I have been installing for 35 years and this is the fastest and most Profesional Sling I have ever used.
    Completely adjustable, and ready to receive any size unit in less than 10 minutes.
    Same cost as Strut/rod nuts bolts and washers.
    Now that is cool metal sling, never seen one in Texas. I have been in industry for 35 years also..
    Dry as a bone Tucson
    Nice install
    Quote Originally Posted by TCreacy View Post
    Tear this one up as well...
    Just equipment and Insulation
    Nice install TC, I'm sure that you are setting the standard in your area.
    Watchman Nee
    Dec 2010
    On a Peninsula in NE NC
    4x4's ok, extra dryer why? what's up with the ductwork
    Mar 2011
    Jamestown,SC
    quicksling
    That looks great but very rarely do I come across an attic with enough hieght to use something like that. Even my help couldn't complain about getting mastic on thier hands trying to seal the bottom of the unit....Awwww!! lol
    Mar 2011
    Jamestown,SC
    I am in the south east swamp. South Carolina. A lot of homes here are old with very low and wide with a low roof line. Usually I build a 2x4 platform with 3/8 plywood, set it on top of the truss and screw it down. I use to use the old metal pan with 4 in. risers but have recently started using plastic secondary. All this usually leaves me about 6 to 8 in. above the unit. I try to talk them into a pkg. whenever I can.I dont get many new installs, mostly changeouts.
    Apr 2009
    South Texas
    Looks like you've got a lot of room to play in the snow!
    Factory installed LL drier, so the second isn't needed.
    As for the 4x4's, I'm pretty sure your local American Standard supply house carries the styrofoam blocks that are 4 feet long, 4"x4".
