Results 1 to 13 of 26
    Feb 2007
    Corpus Christi, TX
    American Standard 2.5 ton Electric Horizontal
    Tear this one up as well...
    Just equipment and Insulation
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	177872   Click image for larger version.
ID:	177882   Click image for larger version.
ID:	177892   Click image for larger version.
ID:	177902   Click image for larger version.
ID:	177912   Click image for larger version.
    Nov 2007
    Sherman, TX
    Looks good from here
    They won't let us "sit" them here....we gotta hang 'em...
    Technical incompetence is NOT a sales tool....
    Fairfield county Connecticuit
    why did you seal the air handler doors with silver tape
    It is a air tight air handler with gaskets on the door panels?
    Sep 2010
    Dubuque, IA
    How did you get keep the snow from melting in the attic?!
    Just messing with ya. I looked at the picture before i read anything, and thought the roof caved in!
    Seatonheating "Well, when you are the salesman/layout guy/installer/owner, you kind of have to watch out for yourself."
    Words to live by my friends.
    Washington
    That white stuff painted on everything is horrid!!! Looks like a cover up for lack of proper transitions.
    I wouldn't put my name on it.
    Monmouth Junction-NJ-USA
    We hang em to. Cannot get away with having disconnect behind unit at all. Has to be off to one side. Above and behind is a no no to.
    If you really know how it works, you have an execellent chance of fixin' er up!
    Tomorrow is promised to no one...
    Feb 2007
    Corpus Christi, TX
    The disconnect is on the 2x4 framing member right in front and to the side.
    We been using snow insulation so that if your up there in summer, it makes you feel liek its winter...
    Phoenix,AZ
    Can you imagine the look on the techs face as he goes to replace the blower motor? I know i wouldn't tape the panel back up, before i left!
    Jul 2009
    Fort Worth, Texas
    Disconnect behind the condenser is no good, the mastic looks horrible, AHU not properly hung, refrigerant lines look like they are run in downspout bought at Home Depot. I CANT STAND CONTRACTORS THAT CHEAP OUT!
    Foil tape on the AHU looks terrible, not to mention it’s not necessary! American Std. has a nice gasket on there AHU's so that you don’t have to do that kind of crap. I would not be proud if that was my work.
    Apr 2011
    Pinellas Park Florida
    install
    tape is horrible, not needed on a new unit, especially a Trane/American standard....we also have to hang the units as well as the drain pans. You should have made a proper transition for that supply, you have a lot of dead air there causing turbulence. Duct sealant should be used for the tape seams only. The condenser should have been moved over to clear the disconnect. We are required to have 3' clearance in front. And that rain gutter for a line set cover is hideous
    Jan 2005
    Orange County, New York
    Why the external filter dryer, there is an internal filter dryer...
    Dec 2010
    Palm Beach,Fl.
    I hate to pile on here but, yeah, its just not a good looking install. Lots of good advice even if its "tough love" Every time I see silver tape all over an air handler I just sit in the attic and weep over my sliced up finger tips hahaha
    Mar 2011
    Jamestown,SC
    One more thing,.... the 4 x 4's under the unit ? I prefer pump risers, look a lot better.
