    Any thoughts on which is better?
    A friend told me the single return was more efficient - the only drawback being that if you start closing doors you disrupt airflow to the single return or you might create a negative presurre in the house.
    more returns then one would be better as long as they are apropriatly located. Usally the only reason you would go with one large one is being it is cheaper puting one in then multiple returns
    Central Kentucky
    Single returns are fine as long as bypasses are installed in the bedrooms to prevent negative pressure in the main body of the house when doors are closed off.
    If the bypasses are not installed you will definitely expierience airflow issues in those rooms that have doors closed.
    Multiple returns are fine also as long as they are pulling within +/- 10% of the airflow being delivered to the room this will also prevent pressure related issues in those rooms.
    Just make sure the air is getting where it needs to.
    Have you set up a Google alert for Carbon Monoxide yet?
    Click here to find out how.
    Oct 2001
    Waterford Michigan
    If you have a choice go with a return in every room allowed by code.
    Ditto!
