Results 1 to 13 of 20
    Jan 2002
    I have an ocean front condo with a 1.5 ton Lennox heat pump that is 7 years old. The outside unit's fins are crumbling when touched. I'm looking for advice on what unit would last the longest in a harsh environment. I've heard about phenolic coated units but Lewnnox's web site doesn't mention this.
    Any particular brand/model to consider?
    Thanks,
    Dave
    Carrier has a coated coil(Coastal Unit Only),only in the builder model ten SEER,as far as I know.
    Their are places that coat coils,try "Broze glow" on goggle.
    [Edited by dash on 07-17-2005 at 03:00 PM]
    In my experience Trane's spine fin coils seem to stand up particularly well in salt air environments.
    leland nc
    i do a lot of work along the ocean front in jersey and have found there is no beter then a another here. seems all brands tend the deterate over 5 to ten years. the closer to the ocean front the faster it would seem.
    i dont know where you live but to give a certain brand and say it will out last any other i cant do. i have found turn off all breaker to kill any power to the unit put a coat of car wax on the casing and hose off the coil a coupletimes a year hepls it to last longer. after an hour turn the breakers back on. the wax will protect the casing and washing the salt and sand out of the coil will slow down the deterating process
    SW FL
    Exclamation HARSH deserves EXTRA
    I'm looking for advice on what unit would last the longest in a harsh environment. I've heard about phenolic coated units but Lennox's web site doesn't mention this.
    or Lennox
    WITH COASTAL PROTECTION
    Designer Dan
    Jun 2005
    Thumbs up
    at the oregon coast its never realy hot or cold. burn beach wood for heat and open a window for cooling. i put in a trane hp. 4yrs ago this fall for my famley. it has held up realy well being 1 block from the beach. i dont think thay have ever ran it in cooling and verry few times for heating.
    Apr 2002
    Trane/American Standard Spinefin will stand up the best.
    Many coatings out there that will extend the life of coils with copper tubes and aluminum fins, but in my opinion they will still fail, before a spinefin ever would.
    Or install a sacrificial Goodman, and replace it every 5 years.
    Maybe Goodman will listen to Robo and use the black paint again. The painted ones did surprisingly well.
    Washing the coils frequently helps. Do not use a pressure washer, especially on a coated coil.
    http://www.ductstrap.com/
    May 2003
    Sarasota. Fl
    Thanks,
    Dave
    I agree with the Trane spine fin coil. You can also purchase a 10 year parts and labor warranty. That way you have "peace of mind".
    Last time I checked the warranty is an extra $100 (plus the regular cost) if within 5 miles of saltwater.
    Good luck.
    It is the job of thinking people not to be on the side of the executioners.
    ~Albert Camus
    Jan 2002
    I live in eastern NC.
    Searching for "broze glow" and "bronze glow" on google didn't turn any coil coaters up.
    I have been advised to clean with water and then spray a teflon based lubricant spray over the fins. Sound or bad advice??
    What kind of premium does the extra coating run? Will the SEER be better if I wait until early 2006?
    Nov 2000
    Eastern PA
    Having worked with Carnak on units that were extensively exposed to super salty conditions I have to agree that the Trane-A/S spline fin coils held up better then coated coils.
    As far why the black painted Goodman coils held up so well, I don't think it has anything to do with the black latex paint that was only sprayed on the outside of those coils. The unpainted Goodman coils are also holding up.
    My only guesses are that either the nonevaporative oil that Goodman alone must use during processing of their coils gives protection against salt air or there is something in the copper to aluminum fin process that retards the reaction that causes the deterioration.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    I have a friend in Galveston, Texas that swears by Cal-Shield. He sprays it on his customers indoor and outdoor coils every year when he does maintenance.
    http://www.nucalgon.com/nucalgon/nuc...4?OpenDocument
    Apr 2002
    Robo has a good bronze glo photo
    Nov 2000
    Eastern PA
    Sure do. These photos are of a chiller coil that has been treated with BronzeGlo. The only sign of deterioration is where BronzeGlo did whatever they do to create a shadow of their name http://www.roboteq.info/bronzeGlow.html?1121653186692
