Results 1 to 13 of 21
    Jul 2005
    I know just enough about HVAC to blow myself up so I thought I would seek advice on this issue. I noticed yesturday that the tempeture in the house was gradually decreasing. Upon further inspection I determined that the 24VAC fuse had blown and I was recieving a lockout signal from the LED. It advised me to change the fuse and it would auto restart in three hours - I assume this is because it is a gas furnace. I waited the three hours and sure enough my furnace powered back on. The inside unit works properly and the heat part works. The outside unit does nothing. I replaced the thermostat batteries. I checked the capacitor it is visually fine and using a voltmeter I determined it is functioning properly. The fan blades are not stiff (I can move them easily). I replaced the outside fuses - just because, made no difference. There is power getting to the motor from the capacitor and when the thermostat is turned on the relay switch activates, makes contact and there is a slight humming noise. I do not know what to or check from here. Local repair company wants $199 for service call and $75 an hour labor plus parts. I want to make sure I've covered the basics before I pay that kind of money to have a fuse replaced.
    You gone as far as you should.
    It may be a simple repair, or a more complicated problem.
    Call a pro, and let him do what we do.
    Central Alabama
    have you checked line voltage with volt meter but note this is not safe for someone with no training but with what you are telling the thermostat is calling for cooling but your contacts are bad or bad breaker or fuse.
    Jun 2005
    pa
    IT SOUNDS.YOU WENT AS FAR AS YOU COULD GO . YOU SHOULD CALL A PRO IN BUT BEFORE YOU DO CHECK ONE OTHER THING CHECK TO SEE IF THERE ARE ANY BURT WIRES OUT AT THE UNIT OR EVEN INAT THE FURNACE GOOD LUCK..
    Apr 2003
    (can't help do to site rules)
    Jul 2001
    Are you trying to get the heat on? You stated you noticed the temperature in your house was decreasing. That is what the A/C is suypposed to do.
    Its along road.
    South Carolina
    where do you get these things
    Dec 2001
    What do "BURT" wires look like ???
    ken
    Jun 2001
    Louisville, KY
    http://www.my-smileys.de
    Apr 2003
    Yep, that's the link... I got it from one of Lusker's post.
    There are others, just search for smileys.
    (you can also go to 'quote' someone and find the link in there post... then click 'back' to not post anything)
    Apr 2003
    Originally posted by troyorr
    Troy, please go to the 'pro business forum' and read lusker's post 'Pro Meeting Please', if you haven't already.
    Thank you for your cooperation!
    You mean "due", not "do".
