Results 1 to 13 of 19
    Apr 2005
    dallas
    Question
    Can I put a sight glass on a split system with a piston?If no why not?
    Nov 2003
    Can you put one on? Sure.
    Will it do you any good whatsoever? Nope.
    Apr 2005
    dallas
    I've been told that you only put them on txv systems.
    Houston,Tx.
    So if it won't do you "any good" whatsoever, Well Boss have you got some other way to tell if you might have moisture in the system? O yes forgot you can take a freon sample down to the chemist and he can test it for you.
    Apr 2005
    dallas
    Will I overcharge the system if i clear the sight glass on a piston or cap tube system?
    South Dakota
    Using a sight glass as an indicator of a correct charge is never reliable for any system no matter what type of metering device you have. However, it is very unreliable as a charge indicator on fixed metering device systems.
    The only real value a sight glass has is for its moisture indicator.
    What method are you currently using to charge systems?
    Apr 2005
    dallas
    Subcooling on a txv and superheat on a fixed metering devise.
    Jul 2002
    Zelienople, Pa
    This is the ONLY way...
    South Dakota
    OK, then you have no need to install a sight glass for charging purposes do you.
    Apr 2005
    dallas
    I know a contractor that is having all his installers put a sight glass on every install.You know that everyone will clear the sight glass when they are charging a system.They will assume there is a txv.If they charge a piston system this way im afraid they will overcharge the system.We know what happens when to much liquid gets back to our pump.
    Jul 2002
    Zelienople, Pa
    Yeah, more service work for you!
    burlington county n.j.
    [QUOTE]Originally posted by NormChris
    [B]
    have seen green moisture indicator on water cooled system flooded with water. i have no faith in them. only use for sightglass is reciever equipped refrigeration unit
    South Dakota
    [QUOTE]Originally posted by t527ed
    [B]
    You obviously had a defective moisture indicator in that sight glass. Don't condemn all moisture indicators based upon one defective one. Something was obviously very strange and out of the ordinary there.
    Norm
