Results 1 to 10 of 10
    Jul 2005
    Lennox HS6-411-FW What is the size of this unit?
    Derby City
    this is a three (3) ton unit.
    Everyone has a purpose in life..........even if it's to be a bad example.
    Seek first to understand, before seeking to be understood.
    Mar 2001
    It is also an old three ton, probably mid to late 60's
    Derby City
    Hmm
    Wirenut; probably heading over to Grainger tomorrow to find a replacement part!
    Mar 2001
    John Lloyd
    You are probably correct. It will be interesting if the unit has the rfc 1 system and they want to replace the condensing unit!!
    [Edited by Wirenut on 07-16-2005 at 10:46 PM]
    It will be RFC. And they'll set the new unit on the old one!
    Must thought it was a high flood zone or something.LOL.
    Mar 2001
    Those old HS6's were one tough unit, the one on top will rust away and the Hs6 will still be there!!
    Most of those were installed with the rfc liquid line, but not all, some had a expansion valve. There are a good many of those old units still in use, they seem to run forever. I recently changed one out for my Aunt, but did it the hard way, I removed the old unit first!! BTW her old unit was 36 years old, does anyone think ANYTHING we install today will last that long??
    [Edited by Wirenut on 07-17-2005 at 12:25 PM]
    Jul 2005
    Does it work to just change the condensing unit? Or does the line set and coil need to be changed out to?
    Originally posted by Wirenut
    John Lloyd
    Don't reuse any 1960s vintage lines & coil but especially the Lennox RFC system!
