Results 14 to 19 of 19
Thread: Building & Housing Codes
07-17-2005, 12:55 PM #14
- Sep 2004
- 3,157
You could be opening a can of worms best left alone.Could be time to hire an attorney.
See since he doesnt own that can of worms , he doesnt care what happens when he opens them---and he doesnt care who it affects
call your electric company out there and have them "clock " your meter
tell your ELECTRIC COMPANY that your apartment is using more power than any others in the complex
STOP TRYING TO BLAME THE HVAC SYSTEM and look for the real reason you are having larg bills
Locate the source of your power consumption---like a refrigerator that runs all of the time----electric heating elements
or that hydronic grow system that you have in the basement or that a neighbor has tapped into your power source getting his electricity free
your power company can help with all of these issues , all you have to do is
#1 ask
#2 dont be a dick-----i know thats going to be a tough one
but they will do more for you if you are civil
and go to the library and look up the mechanical code
if you are that insistant on wasting time and not finding the real reason behind your high electric bills
and dont use the AC at all and see how high it is then
07-17-2005, 06:04 PM #15
- Jul 2005
- 40
If the heat strips or leaking ducts were the problem why would he go to the trouble of totally changing out the outside condenser unit instead of fixing the problem?
07-17-2005, 06:08 PM #16
- Jul 2005
- 40
The A/C never shuts off, isn't that sufficient enough reason for the high bills?
My temperature drop right now is 9 degrees. 79 degrees at the return.
I don't need to do all that research to know that if the AC wasn't running constantly the bill would be cheaper.
If I don't use the A/C at all it will get to 96 degrees in the apartment.
07-17-2005, 06:33 PM #17
Professional Member*
- Nov 2004
- SW FL
- 5,271
Multi- faceted ReSolUtion
Write down Electric Meter readings.Originally posted by ablib
The A/C never shuts off, isn't that sufficient enough reason for the high bills? My temperature drop right now is 9 degrees. 79 degrees at the return.
Turn the A/C off for 24 hours.
Compare to readings from other days when on...
... Last bill: $398 / 30 days = $13.27 /day
Usage ... at $0.10 /kW
__ 2-ton unit = $0.20 per hour or_$4.00 / day.
Present findings to Landlord, All Tenants, City Building Inspector & Lawyer!
I guess you are paying for the electricity
for 4 , 5 or 6 apartment units.
[Edited by dan sw fl on 07-17-2005 at 06:40 PM]Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
07-17-2005, 06:55 PM #18
- Mar 2005
- Houston, Texas
- 11,646
Find the breaker box that is "supposed" to be for your unit.Turn them all to the off position .See if in fact everything is off. If this is a new unit then it's possible that the boxes and meters are crossed. Will the condensing unit and air handler go off if you turn the t-stat off? I've seen many strange and unusual occurences in apartment construction.
07-17-2005, 09:51 PM #19
To the original poster.
I believe your question has been answered to the best of our ability without guessing about your interests. We appreciate your interest in our profession and wish you well.
Thank you for your question and comments.
