Results 1 to 6 of 6
Thread: Hot water Recirculator
07-15-2005, 06:58 PM #1
- Dec 2004
- Indiana
- 11
My hot water recirculator has stopped working. The Grundfoss pump is still pumping however there is no circulation?
07-15-2005, 07:08 PM #2
grundfoss
How do you know pump is pumping?
07-15-2005, 07:16 PM #3
- Dec 2004
- Indiana
- 11
I have a rotation tester that I got from The Grundfoss distributor. You hold it up to the end of the motor and it shows you which way the pump is turning and how fast.
07-15-2005, 07:23 PM #4
If you know pump is working than I would suspect recirc line should be purged. suspect air pocket, this would stop circulation totally. Or impella problem.
07-15-2005, 07:32 PM #5
- Mar 2003
- 8
Wallynut said exactly what I was thinking. There's probably an air pocket in the line.
07-15-2005, 10:03 PM #6
- Dec 2004
- Indiana
- 11
What about the check valve?
