    Iowa
    Question
    i had to replace blower motor yesterday, cause the blade was loose and bent the shaft on the motor. is there a way that u balance the blade? thanks alot
    burlington county n.j.
    with a blade balancer.
    Apr 2004
    Not without spending alot more than just the new wheel costs. Even if you had a way to balance it you would end up having to repair that loose blade. Replace the wheel.
