Results 1 to 13 of 16
    Jul 2005
    Total newbie to AC systems. Where should I go for basic overview of issues, terms, ratings, etc? We are looking at putting AC into second floor addition currently under construction. Only window units currently. Should we put AC only in upstairs (bedrooms) or put in first floor as well. We don't use AC all that much, prefer open windows so won't need cadillac system. Neighbor suggested high velocity system. Worth it? Issues, comparisons with traditional? Heat is hot water radiators so no central air option. Basement is open ceiling and room for air handler but also attic space. Chicago suburbs. 1800SF cape cod house. Thanks!
    Apr 2005
    Houston, TX
    High velocity systems are typically used for installs where you really can't run normal ductwork...like old houses where you don't want to tear out walls/put in soffits to hide the ducts. HV systems are typically more expensive too. Since you're under construction, you can run the ductwork for a non HV system now...no?
    Jul 2005
    Yes, open walls
    I can run the traditional ductwork now in the new construction in the second floor but the first floor is closed up. I could get to it, though from the basement below. I was wondering if the HV would be quieter or more efficient to offset any higher cost. Also, we are open to the possibility of installing AC only in the upstairs (new construction) and not messing with the cost of the downstairs. We can always use a window unit or 2 to supplement the upstairs. Comments?
    HV is less efficient and probably not as quiet as a well designed standard system. Since cold air falls, few vents will be needed on the first floor. Often you can go down through 2nd floor closets with a few runs and the first floor will be fine. I would go with an attic system covering the 2nd floor and pop a couple to the first floor. I think you'll be fine.
    Jul 2005
    Attic system
    Is an attic system any different (i.e. is the equipment different because it is in the attic) or is it just a different location for the air handler? Thanks.
    May 2005
    HV System
    I've designed about 30 of these systems(Unico) and they are not diffused air but aspirated air that mixes with the air in the house so there are no hot*/cold spots in the house. And the system is quieter than a conventional system and it takes about 1/2 the time and space to put one in, plus he fact that you can probably do the first floor from the attic also and depending on sq footage maybe just one system!
    May 2005
    Also because of the air moving in aspiration effect instead of diffusion it is a more efficient system and dehumidifys 30% more!!
    Feb 2005
    Split system
    If you have enough room in attic I would use conventional system having central return on second floor ceiling, a supply in each room on second floor and utilising closets on second floor, try to get three 8" supply to first floor ceiling.
    ( 600 to 700 cfm)
    I have done this many times in existing homes that have hydronic heat, and it has worked extremly well.
    Dec 2003
    Location!, Location!
    Spacepak is a nice spendy system- every one I've done is a success with the HO, but you can't humidify or filter the air with it, which you could with a conventional ductwork system.
    not to mention the wear on the compressor and ofm from constant starting and stopping, due to the freeze stat.
    Jul 2005
    Update
    I've gotten some bids now. The system that seems to meet our needs is an airhandler in the attic with ducts running to each of the 4 upstairs bedrooms. This requires a 2 ton size. Two of the bidders suggested upping to 2.5 ton and placing a vent over the stair well to allow some more cold air to go downstairs and help cool the main floor. (Again, we are using the AC primarily to cool the bedrooms and will supplement the main floor with window units if needed.) Also, 1 bidder installs Lennox but said we could save a few bucks with a Westinghouse system. The other bidder uses Ruud/Rheem. Are these good ideas? Comments? Thanks.
    Craig in Chicago suburbs
    Makes sense to me. Since cold air is going to fall anyway and cool the downstairs, I would go to the 1/2 ton larger size and an extra outlet over the stairs.
    Lennox is OK, don't buy the Merit cheapo series. Westinghouse & Rheem are fine too.
    Jun 2002
    I you have access to the ceiling of the first floor for suppy and return registers, you might consider including it in your system and zoning your first and second floor separately. That way, you can get rid of your window units and still open the windows downstairs if you like.
    Just a thought...
    (Oh, and if you're going the Lennox route the HS26 is a very nice mid-range condenser. The HS29 is similar but lower SEER -- 11 vs. 13).
