Results 1 to 7 of 7
    Unhappy
    My heating/cooling system will not shut off automatically.
    I had a Bryant model 663C ( 12 seer) and Carrier fan coil
    unit installed last March. It uses a Robertshaw 9420
    digital non-programmable thermostat. Any suggestions as
    to why it just keeps cooling or heating until shut off
    manually ? Thanks in advance for your help !
    David
    burlington county n.j.
    bad thermostat
    Southold, NY
    Bad Install
    Florida
    Is the t-stat satisfied(reaches your set temperature)? If yes there's your problem, if not problems with system. If installed in March,call for warranty service.
    Apr 2003
    What makes you not want to call the installing contractor?
    They should be glad to help you with your new system.
    Called installer last Tuesday.
    Guess he's busy this time of year.
    Wanted different ideas from the
    bright folks who populate this
    domain !
    Jul 2002
    domain !
    Why did you wait so long to call him?
