Results 1 to 11 of 11
Thread: replace boiler?
    Jul 2005
    I have forced water baseboard heating and no money but am trying to deal with rising fuel costs. My boiler (1960 American Standard) came with my single story Massachusetts house but is still burning at 78% efficiency. I did have some repair problems within the past year and my oil dealer, with whom I have a maintenance contract, is recommending replacement. I have a separate water heater, 1 zone and used 1100 gallons of oil last year. My downstairs is currently unheated but we'd like to get it finished at some point and that would obviously include heating. What do you think? Replace or no? If yes, what's a ballpark fair price? TIA.
    May 2002
    Colorado
    It would take you 10 years or more to get your money back.
    The AFUE of your boiler is probably around 60-65% because of the stack losses when it is not firing. New 80% AFUE boilers are more efficient mainly because they have automatic flue dampers to stop the heat from going up the stack when the boiler is not firing. An automatic flue damper can be added to an existing boiler, but it may not be legal to do so.
    Maine
    Don't forget the building envelope, ie insulation and windows, these will have a faster payback. The 78% efficiency is combustion efficiency and not AFUE efficiency. Replacing the boiler with a modern one plus some building upgrades will cut your fuel usage.
    1100 gallons of oil is alot for a typical house.....but if the house is over 3000 sq ft, about on target. Alot depends on your lifestyle and what temp you like it at. That being said, no doubt a new oil boiler will save fuel. How much is very hard to say without really looking into the state of what you have now. Biggest savings come by replacing windows and other sources of air leaks, boiler changeouts come just about last on the list actually. Leak-free windows add comfort, something a new boiler will never do.
    Avon Lake, Ohio
    You either have a really big house or your boiler isn't running as good as someone is telling your. It is easy to misfire a burner a make it read higher efficiencies when in fact it may be operating half that good. A new burner should be the only thing that you should consider because the old burner just can't perform to todays standards. Do you know what the BTU's your boiler is rated and what size oil nozzle is being used?
    captain CO
    78% is how efficient the burner is after the unit is fully warmed and at its peak. Annual efficiency is the more meaningful number and yours is likely as low or lower as Panama said. An oversized boiler, which most are, may not run long enough each cycle to get to where it is burning at 78% combustion efficiency. Also considerable off cycle loss hurts old boilers too.
    Best bet is to call another dealer to have a look see. Go over to http://www.heatinghelp.com and go to their find a pro or contractor locator. They have some hot shot oil boiler guys on there who may be able to get you doing better with the current boiler or could help you come up with the best bet in a replacement.
    Avon Lake, Ohio
    Just wondering who makes an oil fired boiler with a flue damper as standard equipment? Haven't seen any! Oil equipment has always had a higher efficiency rating than gas because of the fan on the burner stops at the end of the cycle and restricts the flow of air through the boiler.
    captain CO
    New Hampshire
    Most people in our area use 1000 gals. per year.
    But our electric bill in the summer is low because the AC doesn't run much either. Kind of evens things out a bit.
    New Hampshire
    I'd change the boiler out just because it'll spring a leak in the heat exchanger soon. 45 years old is really pushing it. Plus the repairs on that old beast get to be costly.
    Do improvments to the house, and change out the boiler .
    It will take years to get the outlay back, but you will save on fuel and avoid the risk of a failure during the middle of winter. Not having any money: don't expect the highest tech boiler.
