Results 14 to 18 of 18
07-14-2005, 08:12 PM #14
Banned
- May 2004
- 8,626
Either or will be just fine provided proper installation guidelines and procedures are adhered to.
07-14-2005, 08:15 PM #15
Member
- Mar 2003
- 1,877
i dont take no genuis to fiqure out that the paint is falling off, all the screws are loose and the machine is vibrating all over the place, coils are leaking and most are replaced and all this in about 8 to 10 yrs.
07-14-2005, 08:41 PM #16
flip a coin
a turd is a turd does not matter which of those names is on it
07-14-2005, 08:43 PM #17Originally posted by appltech1
warranty companies use either of the 2 brands and the only bad thing about payne is the Bristol compressor. Goodmans cabinet doesnt fit correctly around the bottom. Gaps.
Either unit can work well with the right installer in charge of the job.
C'mon appltech, that's what silicone is for!!!
Seriously, the new Carriers we have,and the new Addisons, both leak air,so no brand is perfect. As soon as they develope a perfect cabinet, the installer will place it on a warped wooden return plenum box.
07-14-2005, 09:13 PM #18
- Oct 2003
- 2,866
I'm talking condensing unit, OK.Originally posted by RoBoTeq
Just curious; what are gaps at the bottom of a heat pump unit? Are you referring to the drain openings for defrost condensate
Its where the side shell meets the base. There seems to be a lot of places where it just doesnt meet and or look good. Goodman needs about 6 or 8 more screws in it to pull the metal tighter around the edges at the bottom. The top cant be seen unless you turn it upside down
[Edited by appltech1 on 07-14-2005 at 09:15 PM]
