Not quite sure how to explain them. I just worked on a thermal fluid boiler that used a servo gas valve and a servo for the combustion air shutter. The servo operates off a computer network signal and sends back a position signal to the computer to let it know what position it is in. You can set the parameters or tolerences tight on the servo's so that you have a pretty much consistant fuel air mixture for combustion throughout low fire and high fire operation.
