Results 1 to 13 of 14
    Jul 2005
    My new house will be finished some time in Oct. Sould I wait till the first of the year for a new Trane seer 13 air conditioner? I can't get the XL13i now and they want $1000 to upgrade from a XR12 to a XL14i.
    you should be able to get it!
    Derby City
    Somebody's blowing smoke up your backside. Virtually all equipment that will be available after Jan. 2006 is available today, including 13 seer equipment. This is the type of information I am afraid of coming from dealers and vendors that want to get rid of all the old inventory. Give the customer what they want!
    Everyone has a purpose in life..........even if it's to be a bad example.
    Seek first to understand, before seeking to be understood.
    Florida
    Are you in a warm climate with high electricity costs? If you're not then nothing wrong with the 12 seer.JMO
    Jun 2001
    Louisville, KY
    Take a look at ARI ratings. You'll find that the XR12 with TEV equipped coil and furnace with a VS blower will nearly match the ratings of the XL14i with the same goodies.
    Here are some ARI numbers for you:
    THE TRANE COMPANY XR12 RCU-A-CB 248107 4TTR2036A1 TUY080R9V3+RXC036S3 13.00 36000 $238
    THE TRANE COMPANY XL14i RCU-A-CB 548437 4TTX4036B1 TUY080R9V3+RXC036S3 13.75 36200 $226
    Let's see that's $1000 divided by $12 per year difference in op costs...that's 83.3 years to payback.
    If you don't upgrade to VS and TEV coil, then the SEER values are identical!!
    I wouldn't upgrade or wait!
    [Edited by jrbenny on 07-12-2005 at 12:48 PM]
    Jan 2005
    Originally posted by jrbenny
    Let's see that's $1000 divided by $12 per year difference in op costs...that's 83.3 years to payback.[/B]
    Don't forget opportunity cost -- if you invest the $1K at 3.25% instead you'd have a net postive return of $20 a year....
    Jan 2005
    Originally posted by mark beiser
    The XL14i also has better warranties and is quieter.
    Trane's product guide's sound ratings (ARI 270).
    XL14i 2.5T R410A 76db
    XR12 2.5T R410A 74db
    Jun 2001
    Louisville, KY
    10 yr p and l is probably less than the upgrade...
    makes the warranties equal.
    Yes, and if you set those 2 units side by side running, most people will say the XL14i is the quieter of the 2 units.
    db ratings are misleading to the point of being virtually meaningless at times because they do not differentiate between different types and frequencys of noise.
    The recip compressor in the 2.5 ton XR12 is quieter than the scroll in the 2.5 ton XL14i, but the airflow through the 14i is quieter than through the XR12.
    Its all very subjective.
    Jacksonville, FL.
    Currently, there [i]is[/] no XL13i; however, what used to be the XL13i will be re-labeled the XR13. I think it's really the XR12 re-labeled & packaged for the upcoming change of minimum SEER.
    Jan 2005
    FWIW, both the R22 and R410A versions of the 2.5T XR12 have CLIMATUFF® scrolls.
    I thought the 2.5 ton and under XR12 had a Climatuff recip?
    We havn't put in many XR12 units, almost everything we do is XL14, 16, or 19i.
    They used to code it into the model number of the units before the change in equipment in '02, now you can't tell what compressor comes in it till you get it.
