Results 1 to 8 of 8
    midwest
    Have a Rps20BA rooftop not getting power to pump down solenoids for some reason? Wiring diagram is missing, we got a copy of a orginal OM manual but can't read the print. Unit looks modified control wise with relays and wires. I understand that Mcquay might had a tech bulletin on these units to bypass the pump down solenoids due to problems?
    “The price of anything is the amount of life you exchange for it.” – Henry David Thoreau
    It's sad that we have become so accustomed to bad service that we're shocked when we get good service.
    Neil Cavuto
    Metro ATL
    Try this site
    http://mcquay.hvacrcat.com/mcquay.as...zlMcPdcpklikhj,112437&w=r
    Type in RPS and look for the IM (instalation manual) for the RPS Vintage B. You can download a manual there. I will look for a service bulletin on the subject.
    Metro ATL
    That link isn't doing what I wanted it to do. I will try again shortly.
    Metro ATL
    I'm not sure downloading the manual from McQuay is worth the effort. It is a poor scan that you can barely read. Anyone else have any suggestions?
    Jan 2005
    Got to love those "modified" units. Sounds like to me that it is an older machine. Ain't nothin' to rewire correctly, I have done it numerous times with excellent results and running better than the way it was running before I got there.
    When you say "no power" to the solenoids, do you mean it stays in a pump down mode or will not de-energize to pump down?
    Either way it could be a bad wiring problem or a relay that is not working correctly. Trace wires back from solenoids and see which relay(s) are controlling it and then find the control that controls the relay.
    It is possible that the coil itself is bad, getting power and not energizing.
    midwest
    No power to solenoids at all. We will have to trace wires and tag them/label.
    Neil Cavuto
    You might want to check on the output board, next to the relay for the LLSV the mini 5 amp fuse,it looks like a resistor and pulls out with a pair of tweezers/pliers.
    Baltimore area
    BINGO ! There have been problems with some of the older solid state relays on the board (black ones with screw in the middle). Do not rely on the red light to tell you it is powered.
