    Jul 2005
    Red face
    I need a heatpump for a condo on 3td floor. unit is in a balconey vestibule off living room (MUST BE INSTALLED THRU HERE size 36 high 48 deep 60 long).
    exisiting unit 21 high 30 deep 40 long + fittings.
    looking at the 30 end s/r 13x19 and condenser air opposite end (has to be end exhaust) NO NAME.
    any ideas as to a brand/ model
    tough to do a split (room, condo owner)
    Huh?
    He needs a package heat pump heat can install in the utility closet on the balcony.
    But, it must intake and discharge the condenser air horizontally also.
    Off, the top of my head, I can't think of a brand at this moment.
    Feb 2005
    Richmond
    I dont know if this is exactly what you are looking for but Bard makes package Heat Pumps that discharge condensor air horizonatly and discharge return and supply air horizonitly.
    http://www.bardhvac.com/wallhp.htm
    Magic Pak? GE Zoneline vertical?
