Thread: duct less mini split sizing
07-09-2005, 01:43 PM #1
- Jul 2004
- Poughkeepsie, Ny
- 631
Are there any special considerations when sizing mini splits for homes? I've been told there are.
This is what I have. I have a small home with no attic.
2 Rooms connected by a doorway.
Walls = R19
Ceiling = R30
Floor=Carpet
Home is covered in shade
NW=42.21 Double pane
NE= 20 Metal / Foam core door /solid w/storm
29.38 double pane
SE= 17.77 Metal / Foam core door /solid w/storm
5.5 Double Pane
SW= 37.04 Doule Pane
Room 1 is 34 x 15 x 8 Kit/Liv
Room 2 is 21 x 15 x 8 Bed/bath
I came up with 9000 btu's for Room1 and 7000 for room 2. Or 1.5 for the whole home.
[Edited by atufano on 07-09-2005 at 02:06 PM]Happiness is the only good. The time to be happy is now. The place to be happy is here. The way to be happy is to make others so.
-Robert Green Ingersoll
07-09-2005, 01:50 PM #2
Professional Member - T&B bad email address
- Jul 2005
- 172
In my opinion minisplit are overrated in terms of capacity BTUH.
07-09-2005, 02:09 PM #3
- Feb 2003
- 1,996
2 seperate rooms is the issue. You'll never get the second room at the same temp through a doorway. Maybe a 2 zone unit with 2 evaporators, one for each room (9K BTU each), these are pricey.
07-09-2005, 02:13 PM #4
You could use one of those small doorway fans that mount in the corner of the door.
Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
07-09-2005, 02:29 PM #5
- Jul 2004
- Poughkeepsie, Ny
- 631
That is what I suggested, by when you try to route the lineset over, it gets ugly. and the customer wants the discrete look. Plus the supply house wanted to put in a 1 ton unit in that one room. So I suggested we do the one (easy) room and then worry about the other one later.Originally posted by johnsp
[Edited by atufano on 07-09-2005 at 02:31 PM]Happiness is the only good. The time to be happy is now. The place to be happy is here. The way to be happy is to make others so.
07-10-2005, 10:44 PM #6
- Feb 2003
- 1,996
The 9K BTU units are not that costly. I can pick up 2 units for less then a single 2 zone model. More electric wiring and you need the added footprint for the 2nd condenser.
