Results 1 to 12 of 12
    Jul 2002
    NorthEast
    1) I direct connect to the N30 with Windows Dial Up mode
    2) I am able to connect perfectly it shows that I am connected
    3) I already have Project Builder running in Loader mode
    4)"Upload" and "Download objects" is grayed out on the
    tool bar
    5) I click on HVAC Pro Pass thru mode Site manager runs
    6) 5 minutes ,Nothing happens
    I try to run regular HVAC Pro ,am told that Site
    manager is running HVAC PRO pass thru mode
    7) How long does this take
    8) I know I am missing something THE connection status
    window on the Taskbar shows there are no bytes being
    recieved and no bytes sent, but I am connected
    Thank You
    Jul 2002
    NorthEast
    I selected edit site
    I am connected with a null modem cable
    I selected N30 object to edit
    UPload and Download objects is still grayed out
    Correct device name specified for the N30?
    Jul 2002
    NorthEast
    Yes I typed in the exact name of the N30
    Case and Space sensitive
    There is only one N30 on the site
    That's all I've got dude, sorry.
    I'll dig out my class materials later if I get a moment though.
    Michigan
    Smile Try this
    First go into network profiles and check setup...
    unit should auto connect did you build the site??
    Check your passwords and make sure thay are right..
    more info i'll try to help
    also check your com settings..i.e. 9600 or 56000
    Jul 2002
    NorthEast
    I do not think I am performing the
    proper sequence of operations with
    the software
    I open Project Builder Then I open site master
    I have Project builder in loader window
    I think I am missing something here
    Hi CC,
    I dug out my N30 stuff, I have 10 pages on the procedure for up/downloading objects. I'll scan and send them your way if you'll give me a good address.
    Jul 2002
    NorthEast
    Frown
    Thank you very much
    This site has been so educational
    espaecially with all the Johnson info
    cleancondenser@yahoo.com
    I've been slammed at work, give me a day or two.
    Jul 2002
    NorthEast
    We have been having 90 Degree Plus weather
    Everyone is very busy
    Please take your time I appreciate it very much
    Thank you
    You've got mail!
