    according book, the start compacitor is cylinder and plastic case. the run compacitor is metal case and oval. but I met one residentianl air conditon has a plastic case and cylinder capacitor(35uf+5uf). it confused me, because I think all of the residential capacitor is run capacitor. does anybody can tell me is it possible start capacitor?
    that 35,5 is a run.
    Its known as a dual run capacitor.
    The terminals should be marked herm, fan, com.
    Grottoes VA
    A start cap will be round and black (most of them). A run cap will be oval or round, metal or plastic.
    The start cap will have a mfd range ie... 77-83 mfd or 225-243 mfd.
    igwt777 is offline Professional Member - T&B bad email address
    Jul 2005
    That 35uf + 5uf is a run capacitor. 35uf for your compressor (Herm) and 5uf for your OD fan motor (fan)
    Just my .02 cents
    it is very apreciated for all of the valuble information . I just judge the capacitor by appearence before . now I can know it for sure, just like Mr karsthuntr said. the start capacitor have a range of mfd, but the run capacitor has a accurate mfd.
    Austin, TX
    Run capacitor are filled with oil (for cooling and are totally sealed.
    Run capacitors traditionally were made of metal, some are now made of a soft plastic.
    Start capacitors I've seen are of an old style hard plastic material called bakelite. The are filled with paper and a paste material, have a metal retainer holding the top on and a thin circular pressure vent in the top.
    I am for doing good to the poor, but...I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it. I observed...that the more public provisions were made for the poor, the less they provided for themselves, and of course became poorer. And, on the contrary, the less was done for them, the more they did for themselves, and became richer.
    ― Benjamin Franklin
