Results 1 to 13 of 21
    Apr 2005
    I have a new home with a Carrier Infinity 96 gas furnace and I'm concerned about improper airflow. For the supply, people tell me that on HIGH, it should be enough to really blow your hair noticeably -- mine doesn't out of any register. For the return, I did the "paper test" by placing a piece of paper over the return register - some have some suction but not enough to hold the paper fixed, some have NO suction whatsoever !! Are these tests enough to go back to my contractor with? What "rule of thumb" tests can I use to determine if I have adequate airflow in/out of my supply/return registers ?? ...something I can take to my HVAC contractor! Thanks!
    hope u have clean filters, start by reaching hand in register to see if a damper is closed inside the run. returns wont be dampered. probly just a bad run, not smooth, sharp bends etc. if u have access to duct make sure those returns didnt become disconnected. possible inside a/c coil packed w dirt?
    Apr 2005
    Yes, I've covered off all the obvious stuff. Actually, I've tried to tune the ducts/airflow through the use of dampers, without much noticeable success in airflow / home comfort levels.
    Apr 2004
    As for the system, it cares only about what airflow is going through the unit. A properly designed duct system is another thing. You may simply have oversized ducts. I have never heard of a system that is supposed to blow your hair in a home. Where I come from that would be a problem. Did a contractor tell you this?
    My first question would be is the home comfortable and then is the home evenly cooled and heated. If so, then I wouldnt mess with the system. If it isnt, then maybe it should be examined.
    Jul 2005
    pembroke,NY
    I read in a text book from school, that if sytem is installed correctly you shouldn't know its running. The theory is that you wont haer or feel air movement when sytem is on. It will bring house to temp. without you knowing its even on. If your house is staying at your desired temp, then I wouldnt be concerned about how much air is coming out of registers. If its not coming down to temp. then theres a problem.
    Jul 2005
    pembroke,NY
    You would also know if airflow is noy enough, if your evaperator starts to freeze up. After system is running for a while, check large line with insulation on it, and see if it has a coat of frost on it where it enters your evaperator.
    Derby City
    This is exactly why you don't see any bald techs. The h"air"flow technique for determining proper air distribution is a tried and true method. This is why your very best service techs have a full flowing mane of hair. NOT.
    Everyone has a purpose in life..........even if it's to be a bad example.
    Seek first to understand, before seeking to be understood.
    Central Kentucky
    I would not depend on this as a test to determine if airflow was low.
    Have you set up a Google alert for Carbon Monoxide yet?
    Click here to find out how.
    Jul 2005
    pembroke,NY
    Thenks for that link, davidr. I just started in this field and am going by what Ive learned s far. Any info or new reading material is appreciated.
    Apr 2005
    Sure, the system adjusts to set the temperature according to the location where the thermostat is, but this hardly is satisfactory if there are large gradients throughout the home. THIS, HOWEVER, IS NOT REALLY ABOUT TEMPERATURE, but rather achieving the recommended # of air exchanges throughout each room of the house (perhaps I should have posted this to Indoor Air Quality forum ..Ooops!). Thanks!
    Central Kentucky
    bryan,NCI has some great downloads on how to measure & interpret static pressure readings.
    This is the best way to determine a fans airflow.
    Apr 2005
    One thing I do notice is that the original installer definitely uses a lot of the joist work to channel the return air flow -- I thought this was not allowed i.e. building code does not allow use of building structure (???) since it is not intended to provide a proper air seal.
    Apr 2005
    Who wrote this textbook? Come on ... with my fan on at any speed, I certainly expect to be able to feel airflow coming from the registers. But I agree about the hearing part ... the Infinity 96 is quiet for the most part -- better be since it's supposed to be the quietest furnace on the planet!
