Page 3 of 3 FirstFirst 123
Results 27 to 31 of 31
  1. #27
    Sep 2001
    East Stroudsburg, PA
    Originally posted by jrc2905
    Could someone list what is the procedure is for removing the oil from a hermetric compressor?
    Remove compressor, invert for a few hours.
  2. #28
    ravenx you a vorhees or johnstone guy?
  3. #29
    Talking
    "Could someone list what is the procedure is for removing the oil from a hermetric compressor?
    Drill a hole in the bottom of the compressor"
    How do you get your drill "under" the compressor?
    LOL
    [Edited by jrc2905 on 07-10-2005 at 10:16 AM]
    The obvious is obvious
  4. #30
    Apr 2004
    I found sticking a 1/4" plastic tube down in through the suction port into the bottom of the compressor and then sticking another just inside the suction port. Seal around both and blow nitrogen (slowly, very slowly) through the one that you put in second. The pressure will force the oil out the other one. make usre you collect it into a container as mentioned to recharge it with the same amount of new oil.
  5. #31
    leland nc
    doc that has to be the easest and most intelagent ways i have heard of
    even though i only done it 2 times. if i ever have to change the oil in a resi unit i will try this
    thanks
