Results 1 to 9 of 9
Thread: bryant or trane 2 ton heat pump?
04-08-2011, 04:25 PM #1
New Guest
- Apr 2011
- 3
Which one is better?
I got about 1250 sq feet house and I m lookin for 2 ton heat pump inside and out
He set me up with a bryant 2 ton heat pump inside and out , 13 seer.
should I get a same spec trane unit?
how much would that run about and which one would be better??Last edited by wzzp144; 04-08-2011 at 04:45 PM.
04-08-2011, 04:30 PM #2
Banned
- Oct 2003
- Washington
- 7,405
04-08-2011, 04:33 PM #3
New Guest
- Apr 2011
- 3
04-08-2011, 04:39 PM #4
- Jan 2007
- NE OHIO
- 694
sounds too good too be true
04-08-2011, 04:43 PM #5
Professional Member*
- Dec 2010
- Palm Beach,Fl.
- 870
Beware the low price. You may end up with a hack job from some guys that get paid by the job and you're install #2 for the day. But please remove the pricing, before the moderators do.
04-08-2011, 04:43 PM #6
New Guest
- Apr 2011
- 3
04-08-2011, 04:47 PM #7
- Dec 2010
- Palm Beach,Fl.
- 870
Worry more about the installation than equipment. Tough to go wrong with either brand, Trane will probably be the more expensive of the 2, but a bad install is a bad install regardless. Take a look at the Wall of Shame pictures here and witness the horrors of botched installations haha.
04-08-2011, 05:19 PM #8
Banned
- Oct 2003
- Washington
- 7,405
I think garya needs to chime in here. I think he got this kind of deal, and well, the rest is history.......................
04-08-2011, 09:48 PM #9
Model #s?
Trane uses demand defrost which starts defrost cycles only when needed. Bryant is timed so you will defrost 100s of times each winter when it isn't needed. That's A/C mode, so if below about 40 out, once an hour you'll turn on the cooling for a few minutes. Not with Trane.
