    Question
    I'm trying to use a W7751G1003 actuator purely with 24 volts to drive it open and closed. I've taken the Excel board off and have RWWG for wires, thinking that R is hot and the two W's are common for power open and power closed. However, either that is not the case or I have a dead actuator. Or, the G wire figures in there somehow. While I understand the actuator is an ML6161, I don't know if special changes were made for the Excel module. The sticker shows 20-30VAC Rating, but that might be for the board to process. If anyone knows, I'd appreciate it.
    May 2002
    Baton Rouge, Louisiana
    Quote Originally Posted by MatrixTransform View Post
    very soon it is you that will be pwned
    SE Penna.
    The ML6161 actuator is a floating actuator (drive open/drive closed) and uses Red for clockwise rotation, Green for counterclockwise and the whites are common.
    I am not sure about the W7751G controller you have, it shows up as an obselete Honeywell part number. I am looking at a W7751H controller and the wiring scheme is the same, although they used blue wire instead of green.
    Talking
    Thank you for the information.
