Results 1 to 13 of 22
Thread: Um is that what I think it is?
07-05-2005, 11:44 PM #1
Nice new rack From Huss, 6 of the 8 comps are 6D's. What part of this pic would make you want to take a trip to the manufacture and slap the dink upside the head?
Here is a closer look for you to narrow down the focus.
"I'm really easy to get along with once you people learn to see it my way."
"I'll try being nicer if you'll try being smarter."
07-06-2005, 02:21 AM #2
Think Rack maint... Oil change.
07-06-2005, 06:00 AM #3
- Dec 2002
- 317
Rack
It has no !!!!! Discharge service valves, no cushion clamps on discharge lines.
07-06-2005, 06:55 AM #4
Oil change...........
Let's see now.......I'll need oil, filters, plasma torch,.....
07-06-2005, 09:43 AM #5
Can you believe they actually mounted a bracket for press and oil controls right infront of the oil plug? UNREAL!!! there is only about 1/8" infront of the plug before the bracket. Then think about how much fun it will be changing out one of these compressors with the sump hanging below the compressor mounting bolts by a good 2".
07-06-2005, 09:32 PM #6
hi brian
is it possible that the bracket for press and oil controls is removable??
hidden bolts from bellow or side or any kind of attachment?
they can not be THAT STUPID....Don't interrupt me while i'm talking to myself
07-06-2005, 10:01 PM #7
- Jun 2005
- Tampa,Fl
- 102
This is one of the issues that has hurt the American Car manufacturers.Buck-tooth engineering.
07-06-2005, 11:54 PM #8
gerryboy00 Nope no bolts or anything of the sort.
I thought the same thing but they are welded on, not Tacked either, full beads, and from behind so I cant even get a die grinder in there to cut the welds off."I'm really easy to get along with once you people learn to see it my way."
07-07-2005, 01:55 AM #9
I wondered where the Margaux designers went to work.
Had about a dozen Margauxs just like that.
07-07-2005, 09:14 PM #10
- Aug 2002
- 6,047
That's exactely why they make Saz-All's!
07-08-2005, 10:09 PM #11
I just dont understand how stupid they are. I know for a fact if you call the hussman rep they will authorize you to modify as needed and pay you to correct this factory problem. This is a factory issue they know about, but will play it off as they have never seen this..yea right!
Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
07-09-2005, 03:13 AM #12Cutting torches move much faster.Originally posted by R12rules
07-09-2005, 01:46 PM #13
- Jun 2005
- 1
There is a tool you can buy at the wholesalers that will help you on this problem you can put tube in fitting in the base of the compresser and use suction pressure from the rack to push all of the oil out. But the problem then is, the screen behind the plug is still dirty. Then the brackett would have to be removed and installed in a more appropretoe location. hope you have enogh slack in the hoses and wires!
[/QUOTE]
