Results 1 to 13 of 15
    Apr 2011
    Do electric baseboard heater have a seer rating?
    I'm in the process of buying a fujitsu wall unit for cooling and heating, and I want to try and figure out the difference in efficiency between the two.
    So does anyone know what is the equivalent seer rating of standard 1000w, 1500watt or 2000 watt electric baseboard heater.
    Thank you for your help.
    Sep 2006
    Montana
    Electric heat is 100% efficient, meaning everything that is put into it you get back out. Even though you technically don't lose anything, resistive heat is very expensive to operate due to the higher rate that electricity costs compared to natural gas. If your question is whether a ductless heat pump would be less expensive to operate than the electric baseboard, my answer would be yes.
    Heat has no SEER rating, SEER is a cooling rating. Heat is AFUE, HSPF, or COP. Your electric baseboard heat has a COP of 1.
    Apr 2011
    I don't understand why the standard around here in Quebec is Baseboard electric heating, over 90% of the house made today use that form of heating.
    My house which is relatively new, use around 12000KW of electricity per year for heating alone, that's a lot of electricity. My house is extremly well insulated, if I compared to my mother's house which is smaller, it cost her 30000KW of electricity per year in heating.
    I'm trying to figure out if purchasing a hvac is a good investment for me.
    Sep 2006
    Montana
    Quote Originally Posted by shingor6 View Post
    Do you have natural gas available?
    Apr 2011
    Quote Originally Posted by big sky hvac View Post
    Yes I do, but the price of the electricity is so low compared to natural gas that I'm not convinced it's worth it.
    The electricity is around .07$ KW/h for the natural gaz it's a bit more expansive than the average price in the us.
    Jan 2010
    Any Heatpumps up there ?
    I don't know
    Electric heat in quebec makes sense.
    The effective equivalent HSPF of baseboard heaters is a pathetic 3.4.
    A mini-split heatpump is a good option in your case - keep the baseboards for backup.
    12 000 kwh for resistance heat is low - a heatpump may reduce that by 30-40% over the season.
    Cheap to install.
    economic collapse is a certainty. debt based fiat currency monetary systems can never continue indefinitely because they require continuous creation of new debt to service the existing debt. in the absence of economical growth (which is always predicated on increased resource extraction rather than capital alone), this leads to massive inflation which destroys the currency.
    your leaders can't fix this - they're corrupt and only exist to enrich themselves and their corporate friends.
    Nov 2008
    Chapel Hill, NC
    Hydroelectric power, maybe? Plus it's easy and cheap to install. Even so, a heatpump makes a lot of sense in your area.
    May 2008
    OKLAHOMA
    3.414 BTU's of heat per watt. This is an immutable law of physics.
    Nov 2008
    Chapel Hill, NC
    Quote Originally Posted by Texanna Slim View Post
    And???
    Mar 2011
    Montreal
    All the money is invested in the looks of the house and nothing in the heating & cooling system because electricity is to cheap here in Quebec.
    I think we have the biggest market in the world for electric furnaces here.
    Most of the people installs mini split unit when they have baseboards. It's the solution that will cost you less to save. but you still need your baseboards past -12c or -20c depending on the brand and type you wont get much out of your unit. but you will still manage to save quite a bit on your monthly bill.
    May 2008
    OKLAHOMA
    Quote Originally Posted by sktn77a View Post
    And???
    Therefore, there cannot be any of rating for electric heat It is what it is.....3.414 BTU's per watt.
