Results 1 to 7 of 7
Thread: Fan blades
07-05-2005, 07:21 PM #1
- May 2005
- 44
Do they go bad?
Is there a limit when distributor tells tech no more free warrantee replacements for fan blades?
Carrier unit is only 10 month old?
Anyway, can blade be ballanced vs replaced?
<sig>
07-05-2005, 07:25 PM #2
They can be out of balance. Cheap as stuff is made these days, won't surprise me. Should be covered under mfrs' warranty which is 5 on a Carrier.
07-05-2005, 07:30 PM #3
- May 2005
- 44
Thanks, I hope 3rd blade replacement is going to be a winner.
07-06-2005, 09:30 AM #4
could be something other than the blade, the motor shaft could be bent. Might not be fitting up into the venturi far enough.
What is the complaint?
07-06-2005, 10:55 AM #5
- May 2005
- 44
Very loud. I can barely talk with tech, when condencer is running. He was trying to level it with 3/4" PVC.... Still pretty loud.
07-06-2005, 12:45 PM #6
Maybe you can look up and tell us your model number. Sometimes in smaller units (1.5 and 2 ton) the unit is fairly small in its footprint. These smaller units generally have a smaller diameter fan which may have 3 or 4 blades in order to move enough air. One of the Carrier gurus might be able to tell by model. I remember the 1.5 ton LE had 6 blades and was noisy as about any fan I have ever heard.
Also, if its a two blade fan, you may experience a chopping sound but this is usually a low frequency beating noise like from a helecopter rotor.
07-06-2005, 04:57 PM #7
Try cleaning the condensor coils....
