Results 14 to 26 of 39
    never said I could spell
    someone else reading to, too. two much in to things!!!
    in a house, Appomattox, Va.
    getting a unit in a pinch and asking after the fact is a recipe for trouble. Too late to ask once you're committed. And this scenario has come up on this site time and again.
    I am planning on replacing the handler also-as you suggest. I'm trying to reconfigure a linen closet to get the handler inside the house instead of the attic.
    I love you man! Give him a discount for that one
    Col 3:23
    This is true Irascible but most people here thing that is the biggest concern. Hope I spelled every thing Right!
    Mar 2002
    Concord, CA
    Well I'm not sure what you're getting at drk. If you want to talk about a duct's ability to handle static pressure then sure. Even flex can handle up to 10" W.C. long term without blowing up. Since most never see much more than one inch W.C. in the worst of residential cases then there's a lot of headroom in that regard.
    But of course no one is talking about that when they suggest that ducts can't handle a certain amount of air. They're talking about the fact that the ducts may or may not be ideally sized to allow the necessary amount of airflow when matched with a certain blower, coil, outdoor unit, etc. Surely you know that. And if you don't then you perhaps should follow some of your own advice.
    I think drk is right using the same line of thinking you should go with a 5 ton 18 seer condenser, it should match up well with the 20 year old 3 ton 6 seer coil you probably have in the house, 6 in to 18 mean it will cool for 3 times less than if it was a 6 seer but even better because it is a 5 ton which means you will have 2 extra tons of reserve cooling for when it's hot. You know the 13 seer really doesn't fall in here anywhere because 6, 8, 10, seer that you might have doesn't divide into 13 any which way you try.
    If your worried that you existing duct can't handle the "extra air flow" to slow down the air flow just run your filter dirty or when you install a new one only remove half the plastic wrapper this will help reduce the air flow and extend the life of the filter. Once half the exposed half of the filter is dirty the air flow will be reduced, remove the other half of the plastic and re install it on the dirty side, if the dirty side is clogged no need to reinstall plastic. Using this method you should get about 2 years out of a standard glass filter.
    Unless you change the indoor coil you will never see the benefits of a 13 seer condenser, the indoor coil is probably sitting at 6 or 8 seer. The industry only figured that your system would last around 10 to 15 years when it was manufactured so you've got your monies worth. With 20 years on the system do yourself a favor change it all out and be comfortable for another 10 to 20 years.
    Mar 2002
    Concord, CA
    While I appreciate sarcasm as much as anyone yv, yours had no substance. If any of it was for my benefit then please point out any factual errors on my part and I'll gladly recant. I don't think you can. Not everyone drinks the new equipment hustling Kool-Aid.
    Irascible so you also go by the name drk? I don't see how you think I was talking about you, or may be the follow up post is the one you are referring to?
    Mar 2002
    Concord, CA
    LOL. Nope. Excuse the misunderstanding. We'll tango another time.
    To many people or worried the duct will not handle the extra air flow! Their are not many out their that will not!!! Most people need to grow up!!!!
    Steve , you beat me to it but I was thinking the same thing
    to many people ARE worried the duct will not handle the extra air flow
    There are not many out there that will not!
    Most people need to grow up---
    Dear mr FRAMING contractor
    There is a good reason that to many people are worried the duct will not handle the air flow-----THERE ARE MANY THAT WILL NOT AND YOU ARE NOT GAINING A THING BY DOING SO!
    You are a framing contractor---do a manual D
    most people need to ask a question and listen to the answers these people gave you , they are not telling you how to pound nails or salt
    Jul 2005
    Thanks for the good advice.
    I cancelled the replacement this morning (the guy who didn't even do a leak test) and called the company I've dealt with in the past (which was too busy to come out yesterday). I've taken your advice to slow down (and do it right)- though it's tough to overcome the impulse to get cold as quickly as possible.
    Thank you again- didn't mean to step on any toes.
    Jan 2005
    An excellent move. Please come back and let us know what the second opinion says.
