Results 1 to 8 of 8
    Jul 2005
    Where on my A/C system is the size of the unit? On the compressor or air handler? e.g 1 ton, 2 ton.
    Thanks.
    Mar 2002
    Concord, CA
    The model number of the air conditioner is your best bet. It and other data should be on a sticker on the outdoor unit.
    Jul 2005
    Ok here are the specs:
    Goodman Manufacturing
    Houston, TX
    Model # CPLE24-1C
    Hopefully someone here can tell me the size of the unit based on that.
    My guess would be 24 = 24,000 btu's or 2 tons.
    Jul 2005
    Is 2 tons enough for a 1350sq ft apartment in southern missouri. Where it rarely goes above 95?
    Apr 2003
    First, your unit is definitely a 2-ton unit.
    Second, there is no way for anyone here to tell you whether it is the correct size for your home! A load calc is in order to answer that question. There are many load calc programs out there... one at the top of this web-site. Click on the red dot and do your own load calc if you wish.
    Mar 2002
    Concord, CA
    First, jultzya is right.
    Second, two tons is definitely enough if you have a downstairs apartment. You may or may not be pushing your luck if it's an upstairs apartment. How do I know? I have a crystal ball.
    Jul 2005
    Upstairs apartment.
    See problem here:
    http://hvac-talk.com/vbb/showthread.php?threadid=79565
