    Apr 2005
    Virginia
    What is the proper charging procedure on a system that contained a leak in which all ref. was recovered, leak fixed, pressure tested with nitrogen, and pulled a vacuum down to at least 500 microns? Should the system be charged with liquid or charging with just gas ok? On a R-22 system I should say.
    Apr 2005
    NE PA
    Both work, but liquid is sure a whole lot faster.
    Paul
    Louisiana
    I charge by method of liquid, if you do charge by liquid go slow with it, don't juice it all at one time, as you may know charging by liquid will charge it up fast so be careful not to grossly over charge the unit.
    Aug 2001
    if its empty and you still can read the data plate why not just weight the charge in
    davenport, iowa
    if system has a king valve, then you can feed liquid into king valve until you get close to the charge level or until it stops taking liquid at a reasonable rate, then trim the charge with vapor or liquid throttled at low side of manifold, if it can't be pumped down and recharged as above, then you can throttle liquid at the lowside of your manifold, but be careful.
    Da Threadkilla
