Results 1 to 7 of 7
Thread: york relay board
04-05-2011, 09:51 PM #1
- Jul 2007
- 65
york relay board
York d3cgo09on16558d, just wondering I cant jump out unit and I have 24v at transformer which feeds board. The 24v to wire harness to ground is 24v but at terminal strip on board from r to y r to w r to g etc i read 0 volts. possibly stupid question but from this info is the board faulty or i missing something?
04-05-2011, 09:54 PM #2
did u go from r to ground ?
work to live not live to work.
04-05-2011, 10:04 PM #3
- Jul 2007
- 65
yeah r to ground from terminal strip on board has 0 volts
04-05-2011, 11:21 PM #4
I think you answered your own question
What does logic tell you?
04-06-2011, 03:24 AM #5
New Guest
- Apr 2011
- 1
if you have zero volts at the board then it's not the board. Check smoke detector if it has one. A bad board would have 24v at input of board (where the screw terminals are at the board) and 0 coming out. Check for broken wires or tripped safeties. no 24v at board means no power! Most of them have red l.e.d.'s to let you know your getting power.
04-06-2011, 08:27 PM #6
- Jul 2007
- 65
Logic tells me I was the smartest guy on the roof top at the time but I am the only one who came up the hatch. Found 3 amp circit breaker open perhaps what threw me that the reset wasnt tripped. Thanks for the help, might have changed relay board prematurely, stupid brain.
04-06-2011, 09:00 PM #7
- Sep 2009
- Boyertown, Pa
- 50
