This alarm usually means you are not moving enough water thru your cooler?evap barrel. Make sure you have proper flow. This alarm helps prevent freezing cooler tubes. Will help more if you provided a model and serial#
What is the meaning of "Low cooling flow" on Carrier chiller?
Thank you PortaChill.
What kind of chiller is it ?
Need 2.4 gallons per minute per ton.
Refer all arguments to the wife, she's better at it.
www.fairtax.org
