    Question
    I am wondering what size is this evaporator coil.
    Also how many cfm's should it be moving?
    Is the blower one speed or can it be set from low to high?
    Carrier
    Here is what the lable says:
    CAC/BDP 7310
    West Moore Street
    Indianapolis, IN 46231
    Evaporator coil
    Lis 3R39REFEVAP
    Mod# CK3BXA030017AAA
    Ser# 3503X30116
    Design Pressure 450 PSIG
    Refrigerant R-22 and R-410A
    Made in Mexico
    Feb 2005
    In a van by the river
    I'm guessing a 2.5 ton
    ## + years in the field never made you a know-it-all This industry is far more diverse than you are
    Here is the info on the furnace:
    Model number- 58STA070---10112
    Seriel number- 1504A26266
    Series 100
    Max unit amps 6.7
    motor HP 1/3
    force W 2.49
    How many CFM's is this unit capable of?
    What size is it?
    Can the blower be adjusted from low to med to high/
    Feb 2005
    A 2.5 ton system would require 1000 cfm of air. Most all furnaces are equipped with at least a 3 ton blower. Carriers have multi-speed blowers and yes there is high, medium, and low. High speed is going to be a black wire of the blower motor. You may want to call a qualified person to verify speed selection is to your satisfaction
    I switched blower motor to Medium Low to see if it makes a difference in the cooling in the house.
    I have a 1700 square foot house.
    Will changing the blower setting affect how much freon there needs to be?
