Results 1 to 13 of 17
Thread: Foot in Mouth
    May 2005
    Mississippi
    Not a real problem, "I HOPE!" but last night I replaced the contactor on the condensing unit for my neighbor. (Tempstar 3.5 ton, circa 1999) the compressor cycled, but the fan would not shut down on the CU.
    After I finished and had their system up and running again, I was have a beer or 12 with my neighbor at my home when I made comment that I had not had troubles with my CU (exact same one as his). about that time we walked into the house (needed more beer) and I noticed that it was 77 degrees on the t-stat, blower was working, went outside and CU was not running.
    Tripped breaker, damn and I was bragging on this Tempstar P.O.S. Reset breaker and started system, pulled cover off disconnect and check amp draw. 18.6 on both legs, Panel gives FLA of 18.7, so all is good.
    Just makes me wonder if I need to quit bragging on the quality or non-quality of equipment.
    Although I iwll be glad when this one dies so I will have an excuse to put a Carrier or Trane system in.
    Regards
    Feb 2005
    What are you thinking???
    From the pan into the fire...
    Heh-Heh
    Have a beer on me.
    S.W. PA
    should have knocked on wood
    May 2005
    Mississippi
    Still curious as to why that darn breaker tripped though,
    Hoping was a thermal trip. heat Index was over 100 yesterday here and is expected to be 109 degrees heat index today.
    I wish someone would tell the damn weatherman that its not August in Mississippi yet.
    Apr 2003
    Please tell me how this is happening!
    May 2005
    Mississippi
    Hmmmmm I give up... why?
    Bet I know...
    Jun 2001
    Originally posted by control_noob
    Bet I know...
    Check to see where you put the common wire at. Just a hint.
    Nov 2001
    Is it just me ?
    But almost 19 amps sounds high for running amps.
    Must be under a good load.
    If you try to fail, and succeed.
    Which have you done ?
    Well, more then once while rushing, i've put the fan wire on the line side of the contactor, thinking i was putting the cch wire on.
    Always curse myself out when i do it .
    Nov 2001
    usaully if you multiply the running amps by 5 or 6 .
    that would give a close expectation of the start amps
    18x5=90
    19x6=114
    maybe your breaker is getting weak.
    Apr 2005
    San Luis Obispo County, CA
    Regards
    Actually, don't you know that all mechanical equipment talks to each other? You put new parts in your neighbors unit, now yours wants some too. Sort of like replacing the condensor fan motor only to have the compressor fail a week later...
    May 2005
    Mississippi
    Bet I know...
    I replaced the contactor on my neighbors unit, its perfectly fine.
    It was my unit that tripped the breaker when I was braggin on it never giving any trouble.
    Regards
