Results 1 to 13 of 30
Thread: Mold mildew or soot
04-02-2011, 05:42 PM #1
- Apr 2011
- 12
Mold mildew or soot
Walls were sorta blackish, put all new siding windows , scrubbed walls with T.S.P & repaint , brand-new carrier 19 ser. Unit. new roof. & still get slight black on walls Help!Thanks Tonymy wife likes to burn candles !!
04-02-2011, 05:44 PM #2
Professional Member*
- Feb 2011
- North East Ohio
- 653
I'll bet you a buck it's the candles. Do you have a gas furnace? Gas water tank?
04-02-2011, 05:44 PM #3
candles are nasty, will leave a sooty mess every time.
04-02-2011, 05:51 PM #4
Mildew is mold growing on cloth.
I'll place my bet with it being the candle. Also, if it is a scented candle, you are wiping out your resperatory system and taking a risk of formicary corrosion on your new indoor coil as well as deterioration of the furnace heat exchanger from the acids formed by wetting and heating the chemicals used in scented products.Government is a disease......masquerading as its own cureEcclesiastes 10:2 NIV
04-02-2011, 06:08 PM #5
- Apr 2011
- 12
U can see were the nails are , buy the black dot from the nail heads & mainly outside walls are the worst I think the candles don't help , that y she does not burn them anymore removed woodburner which s:$&;& is there a company I can send a sample of the residue that I wipe off? And send it to them+ how about a fresh air intake system tyed into my new system! plus I have a dehumidifier that pulls about 1ta2tanks of water .
Thanks Tony
04-02-2011, 06:13 PM #6
- Feb 2011
- North East Ohio
- 653
what part of the country do you live in? do you have gas appliances in the house?
04-02-2011, 06:24 PM #7
- Apr 2011
- 12
All electric live in MD
04-02-2011, 06:28 PM #8
04-02-2011, 06:32 PM #9
- Apr 2011
- 12
Brand new Carrier 19 ser. Every thing electric.
04-02-2011, 06:58 PM #10
04-02-2011, 08:01 PM #11
- Apr 2011
- 12
its all inside. and like i said i scrubbed walls plus used a prod.Kiltz then, painted
and it returned u can see were the wall studs r by the nail that are black in color, new carrier a/c 19 seer.new siding windows( Anderson) house wrap. And problem was before we did all this work That is y we did all the work actually thought the a/c was the culprit and like i said the wife use 2 burn candles but not any more ..also i have a dehumidifier that puts out about 1and3/4 buckets aweek
Thanks ,Tony
y
04-02-2011, 08:04 PM #12
- Apr 2011
- 12
All ellectric
04-02-2011, 08:05 PM #13
- Apr 2011
- 12
All electric
