Thread: txv vs. pistons
    what are the differences between how a piston or txv modulates refrigerant flow? what are the pros and cons of both ~~just curious~~
    Apr 2005
    NE PA
    Quick answers: piston is a fixed oriface which is perfectly optimized at only one set of operating conditions. TXV is a modulating valve that varies the expansion flow of the refrigerant by a balance of liquid line pressure and vapor line temperature. TXV provides a better metering of refrigerant as conditions (temperatures and heat load) vary.
    TXV: more complex, can fail due to a number of reasons, better load matching, thus higher potential SEER
    Piston: Simple, cheap, virtually no failures other than clogging, less than optimal mereting in varying conditions.
    paul
    Houston,Tx.
    Hey, I like those pistons they work really well with a variable speed compressor.
    May 2002
    Colorado
    And TXVs are far more forgiving of charging errors when Mr. Bill does it by pressures alone.
    Hey!
    He keeps a cold beer in his hand to double check his charge. LOL...
